Pre-Owned Honda CRF's
crfsonly.com :: View topic - 2010 Honda CRF450 Motocross bike - ECU interface
The time now is Fri Nov 20, 2009 8:27 pm | Log in to check your private messages
Album Register Log in
Post new topic   Reply to topic    crfsonly.com Forum Index » General Discussion
Author Message
b-town
PostPosted: Sat Nov 07, 2009 3:50 am    Post subject: 2010 Honda CRF450 Motocross bike - ECU interface Reply with quote
Hi All,
Does anyone here know, or know how to find out the communications protocol used by the 2010 ECU interface? I need to read throttle position, RPM etc. from the ECU using some custom electronics (I know the Honda FI tool can do this, I need to know how!). Any help would be greatly appreciated.
Thanks in advance for any input Smile
View user's profile b-town's Garage Send private message
Back to top
2005 Honda CRF450X
PostPosted: Sat Nov 07, 2009 6:38 am    Post subject: Reply with quote
Prolly simple ascii. Smile Just a hunch.
View user's profile paul turner's Garage Send private message
Back to top
b-town
PostPosted: Mon Nov 09, 2009 10:57 am    Post subject: Reply with quote
I really need to know the interface details including the phy level used. Anyone else have any clue or know anyone who does??
Back to top
AgentSmith
2006 Honda CRF450X
PostPosted: Mon Nov 09, 2009 10:59 am    Post subject: Reply with quote
I'm sure the engineers at Honda aren't sharing. They don't want aftermarket companies knocking off their PGM-FI tool.
"Make a man a fire and he'll be warm for a day.
Light a man on fire and he'll be warm for the rest of his life."
View user's profile AgentSmith's Garage Send private message Send e-mail
Back to top
mikey526
2007 Honda CRF150R
PostPosted: Mon Nov 09, 2009 5:57 pm    Post subject: Reply with quote
What about Yoshimura and the few others that must have figured something out? I guess Yosh has close ties with Honda racing but what about the other companies?
View user's profile mikey526's Garage Send private message AIM Address
Back to top
AgentSmith
2006 Honda CRF450X
PostPosted: Mon Nov 09, 2009 6:59 pm    Post subject: Reply with quote
They haven't cracked the Honda OEM unit, they replace it with their own ECM and harness. Their unit plugs into the throttle body, the crank position sensor, the TPS, etc.
Back to top
mikey526
2007 Honda CRF150R
PostPosted: Tue Nov 10, 2009 5:20 am    Post subject: Reply with quote
Oooooooh that makes sense. I didn't know that.
Back to top
PostPosted: Tue Nov 10, 2009 6:38 am    Post subject: Reply with quote
Multiple issues here:
1) The CAN/LAN analyzer equipment & software license needed to communicate on the bus is expensive.
2) You would need to know the serial commands to change anything. Even if you get the protocol identified, you wouldn't know how to communicate on it. Normally, CAN/LAN protocol comes with a hefty user manual. This is all proprietary to the OE.
Last LAN based protocol I needed to be familiar with came with a 1,100 pg manual and a $20k piece of equipment to test on it. Probably an extreme case given what Honda needs to do on a motorcycle, but you get the idea...
05' Honda CRF450R
06' Honda CRF50
00' Honda XR80R
View user's profile 124's Garage Send private message
Back to top
DezertTim
PostPosted: Tue Nov 10, 2009 6:52 am    Post subject: Reply with quote
but are they even using anything close to a CAN system when your only running an engine and its only a few parts at that? the way i see it, its using a giant relay to switch an injector and a spark plug....but then again i do work on over complicated german cars everyday.
I have worked with guys that have done the reverse engineering on the bosch and simos control units used by bmw/audi/vw/porsche and so on. its a long proscess.
2007 crf 250x
2002 cr250r
2003 chevy silverado/ camburg long travel
2004 audi s4
View user's profile DezertTim's Garage Send private message
Back to top
PostPosted: Tue Nov 10, 2009 8:09 am    Post subject: Reply with quote
The ECU on the CRF's must have some sort of CAN, even if it's simple. Otherwise, the $300 tool is no more than an expensive PWM module. Which is possible... Rolling Eyes , but I doubt it.
05' Honda CRF450R
06' Honda CRF50
00' Honda XR80R
Back to top
Display posts from previous:
Jump to:
