It doesn’t happen all the time but it does seem to be worse and happen more often when I’m riding trail verses when I’m riding track. Whether the bikes hot or cold doesn’t really seem to have any effect on it. If i let out the clutch a bit with out giving much gas and then pull it back in it’ll clink a couple times and then stall almost every time. I haven’t taken off the cover yet but I’m planning on it tomorrow if I have the time. If the basket is notched will the basket just need replacing or does something cause the basket to notch that I’ll need to fix. ThanksWelcome to the site !!
It could be a few things , can you give a bit more detailed description of what occurs when it does this , like frequency (does it do it every time ?) , is this only when the engine is cold ?? , or after riding for a while ?? , what type of riding are you doing when this happens ?? (MX track , trail , etc. ) , have you had the clutch cover off and or removed the clutch disks ??? , is there any notching of the basket itself ???
The more detailed explanation you can give will help diagnose the issue
If the basket looks like this (below) then that is most likely the cause
Copyright 2016-2017 © CRF's Only Forums. All Rights Reserved.
