by Aussiecrf230 » Tue Nov 03, 2009 3:42 am
You will probably find that with the compression back to normal there will be a little extra heat.
No way you would normally be able to touch a hot cylinder and the expansion chamber would remove skin.
If it is running good leave it alone and don't use less oil than 32:1 mix, no matter what the oil manufacturer says.
